T4 question
Old Oct 1, 2008 | 11:29 AM
Moonstone Steve.'s Avatar
Moonstone Steve.
Default T4 question
wot would be the differance with running a T4 with .63 and .82 exhaust housing on the same engine.
Ta,
Steve
Old Oct 1, 2008 | 11:33 AM
Nash's Avatar
Nash
Cake lover!
More Lag, with the .82 that is.
Old Oct 1, 2008 | 11:36 AM
Moonstone Steve.
Kinda guessed that m8, i aint driven a T4 cossie so im expecting some lag, was woundering if the extra power would be worth it or not.
Steve
Ps. it will be a roller bearing core type if it helps.
Old Oct 1, 2008 | 11:42 AM
Nash's Avatar
Nash
Cake lover!
I have never diven a RB core version so i cant comment sorry bud.
When the turbo gains full boost depends on loads of things like cams and mapping etc. I had full boost with mine just before 4k rpm but only reving to 7.2k, thats a very old skool T4 and Greys set up.
Other T4 cars wont get full boost till 4.5k but rev to 8k. Like i said it depends on spec really.
Old Oct 1, 2008 | 11:47 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You shouldn't get any additional power really (without seriously compromising reliability).. an RS500 T4 is flat out at 480bhp on a YB and going above this just reduces its service life.
Old Oct 1, 2008 | 04:07 PM
dave cos4x4's Avatar
dave cos4x4
would it not be able to get rid of the waste gasses good enough,surging may happen...depending on boost of course.
Old Oct 1, 2008 | 04:19 PM
scoooby slayer's Avatar
scoooby slayer
afaik if the gases cant escape it will get boost creep as turbine will be getting to much air and trying to raise the boost. surge is boost air flow that has nowhere to go.
Old Oct 1, 2008 | 04:24 PM
dave cos4x4
thats what i said.
Old Oct 1, 2008 | 04:36 PM
col cos1's Avatar
col cos1
ive got the best of both worlds now,comes on boost at 3500,strong at 4 and holds it to 7800rpm limiter
mine has been played with but not roller bearing
Old Oct 1, 2008 | 04:41 PM
Rab's Avatar
Rab
Fucking superstar........
Would it really increase lag though? I would have though that wouldn't really be affected. I would think boost threshold would move up the rev range though? But surely the time to boost while inside the boost threshold wouldn't alter all that much?
Feel free to call me a cunt if I'm wrong
Old Oct 1, 2008 | 04:47 PM
Nash's Avatar
Nash
Cake lover!
I was refering to threshold Rab, the reason i didnt put lag was because alot people understand threshold as lag.
Old Oct 1, 2008 | 05:05 PM
J1mbo's Avatar
J1mbo
B1mbo
flat out at 480 ! wouldnt have thought so !
rainbums old t4 engine which was about 510 ish IIRC
t4 is flat out at about that ^^^^^^^
and this still did loooooads of miles so i think 480 is a bit low
Old Oct 1, 2008 | 05:18 PM
Rab's Avatar
Rab
Soooo... I'm wrong because I'm right? Is that right, or wrong?
Old Oct 1, 2008 | 05:22 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Ta,
Steve
Depends what you mean by a T4. If you mean an RS500 turbo, its pointless.
If youmean a different turbo all together, as there are millions of T4s in the world, there may be a good point to it.
Old Oct 1, 2008 | 05:44 PM
Nash's Avatar
Nash
Cake lover!
Your wrong because you are right in what you said
Old Oct 1, 2008 | 05:46 PM
Rab's Avatar
Rab
Ah balls
Old Oct 1, 2008 | 09:14 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Flat-out being what it's rated for.. ask your dad about how the 50 and 57 trim compressors vary!
Old Oct 1, 2008 | 09:21 PM
J1mbo's Avatar
J1mbo
B1mbo
sorry i thought you ment flat out by max horses they can make lol
jim
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
