Maybe an interesting thing to do on here with the various popular engines...?
A few years ago they did this on another forum, they made graphs using proven power and torque figues only, all with the same capacity engine (5litre) but all other specs were totally random.
Only things taken in to account is boost and power/torque, but still came out with an interesting corrolation....
Power seems more sensitive to other changes, but torque follows boost bloody closely.
Maybe something similar should be done on here too, just out of interest? Obviously it will take someone to plot it all on a graph, and people to post up their numbers, but it would be interesting all the same.
I don't really see a point to that to be honest. There are too many variables not kept constant so in what way is any of the above a fair comparison? The equations per line factor in too many variables not kept constant.
There ARE millions of variables, but as those fuckign graphs show, regardless of all the variables, it comes out pretty fucking close just going by boost...
That may be the case in that situation, who's to say it will be the case given ANY engine? You are suggesting by taking those equations I will get a rough output of what my car makes JUST on what boost it has? And the only factor considered is a stock head and aftermarket head. If I told you I had a 5.0 Mustang engine with 23psi boost, you could tell me my bhp and torque output accurately? What is the error margins of those graphs? Did the person producing them give what the errors were?
For example I could be running a baby turbo on 20psi or be running a fucking mahoosive fucker on 20psi. Outputs would be a lot different surely?
The stock and aftermarket head is NOTHING to do with this, they just added that out of interest, its totally irrelivant to us.
Nobody uses stock heads unless its a 100% standard engine and they have no money and just building a car from scrapyard bits.
What you said is my point, it would be interesting to see if YBs also follow this similar bhp or torque corrolation, dont see why not, the 5.0 isnt magic, its just an engine...
There are millions of variations in the engines above, they have a LOT more variations than in YB tuning, countless different turbo sizes and makes, manifolds, cams, heads, compressions, everything, as there isnt a set way to do things like in Cossies and RSTs.
But they STILL ended up with that suprisingly close corrolation.
Going by that, YBs or RSTs should be even closer to the average line maybe?
Which is my point. Interesting.
Yb's from the people I know well will have a MUCH higher standard deviation from the norm than on those graphs I reckon.
But maybe you are right that the scene as a whole will have a lower standard deviation.
Rod's for example, has torque figures that would sit him WAY WAY off the line.
Would be very interesting to see though I agree, if only cause it would put into perspective just what people are managing to achieve relative to each other.
The only thing I would say though, is it would HAVE to be all on pump fuel to really have any meaning at all.
And what the graph does do, is make you look closer at the ones that stand out from the norm, as they clearly the ones worth looking at.
More varied than from a T25 to a GT42R, which is the variety on here from the engines?
The figures on that graph go from over 400 to 1200 bhp.
I wouldnt say that is more variation than from the 204 to 800 that we have on here over a similar variation of boost.
In fact, quite clearly it isnt.
I think the YB tuning game is more varied than you give it credit for
What I think would be the most interesting thing to do, would be one graph with lots of different types of engines on it, so YB's, those 5 litre lumps, bike engines etc.
and show torque per litre per pound of boost absolute
I reckon there would of course be variation, but I think less than people would expect.
And the figures on that graph go from 200bhp to 1100bhp and 250lbft to 1100lbft, much wider than it will on YBs at both ends.
Those cars go from NON turbo stock engines, to twin T25 on a stock engine, to race fuelled thumper turbo'd monsters. There is no set way of tuning them like YBs, I doubt there more than 2 cars with the same sorta turbo or turbos on that whole graph.
They go from stock iron heads to iron gt40s to loads of different brands of aftermarket heads, each countless valve, port, runner and chamber sizes, many even with ports and plugs in different places, again, doubt there more than 2 cars with the same type head.
Same goes for cams, the variation they use is riduclous, and same for compression, id bet it varies from 7s to 11s.
Inlet and exhaust manifolds too, I doubt more than 2 cars run the same.
The exhaust manifolds are stock ones adapted, log ones, tubular ones, all kinds of lengths and bores.
Inlets are similar, ridiculous amounts of styles and sizes used, not to mention some carb and some injection.
And you think there is more variety here? I certainly dont, not by a long shot.
BUT despite all that, there is a bizzarely close corrolation between it all, especially in torque, so it would be interesting to see if its the same on YBs, as no reason it shouldnt be with all engines, making it an interesting thing to do if someone can be bothered, no matter how much you are trying to pit it down.
Like the drugs thread, its probably best you understand the other side of the argument first.
And I bet there is more LCA variation on here than from that chart too, as anyone with a set of verniers can change it on here, but with single cam engines, its a custom grind just to change your LCA be even 1 degree.
I know people with everything from N/A YB's on carbs, upto Rod with his GT42R engined monster.
I dont agree there is just a set way of doing things at all, if there is, then where does martins longblock fit into that, or rods engine, or mike rainbird on his ITB bit cc setup, or the N/A converted cars?
Sure there is a mainstream, as with any car that is turbo from the factory, as no point changing manifolds if you dont need to, but on the edges of that, there is a massvie amount of variety which doesnt fit in at all with your "set ways" theory.
Im not being gay or arguing, its just as with so many threads, your starting an argument (that YBs wouldnt work with this graph as they so much more varied, which is totally wrong, as shown) for no reason apart to I dunno, entertain yourself, look clever, try and show how right you are and how wrong you can make others look, be annoying, im not sure.
And once again, when shown wrong, you will argue till the death about it pointlessly, ruining yet another thread just to get the last word.
When in reality, none of your comments needed saying, all that needed to happen is if someone fancied doing it, they should, as it would be interesting to see, just as those graphs are.
Im saying the BHP one would have a larger standard deviation based on the engines of people I know.
And im saying it would be interesting to see.
Fuck knows where you are getting all the other crap you THINK im saying from, cause you are wrong.
Loosely speaking im of the opinion most engines will fall relatively close to 80lbft per litre per bar of absolute pressure, as thats my experience across many different engine types, from 5 port right up to multi valve quad cam etc.
BHP will vary a lot more, torque wont.
you hadnt been and edited your post when I first replied, so I didnt see these bits:
If im actually shown to be wrong, all I ever do is say "oh thanks, didnt realise I was wrong", doesnt happen often though, as I dont post things in the first place if they are wrong of course as im not like that, I like things to be factual, and in the thread you mentioned, I was giving my opinion, and it was 100% factually correct to be my opinion, and was displayed as such, so fuck knows what you are twittering on about now just for the sake of it?
You made comments that the YB scene had no variety in it, I said that I could think of plenty of varied examples, I dont see why you would be of the opinion that my take on that needed saying any less than yours did?
You tried to say that the YB tuning was way more varied than the 302s, even though you know nowt about them.
I proved you was wrong with factual infomation, making this idea as revelant to YBs as any other engine.
You carried on and on, and no doubt will more, having already properly fucked this thread.
oh look... Chips going on and on and on again x1000
its literally every thread... Seriously Chip, are you this boring away from the keyboard..? oops, I forgot, your never away from it LOL
http://www.migweb.co.uk/forums/engin...ml#post3765555
Where someone corrected me on a typo I had made that was quite misleading, so I thanked them for correcting me, I didnt argue about it like you are implying I would.
The reality is simply that you just arent very good at reading things accurately, so often misinterpret them, and its your interpretation of what I have said that is wrong, not what I actually said.
The closest I came was:
No you didnt, you proved wrong some things that I never said in the first place, but that you claimed I said, which is a VERY common theme with you, you read something Ive read, you then think it says something different, and then you argue with the something different, I point out that wasnt what I said at all, and you go round and round in circles keep making up things that you claim Ive said when I havent, and I keep correcting you.
You said all YB's follow the same route, I pointed out they dont.
I said that the YB's im familiar with, the likes of Rods, would show a larger standard deviation than on the graph.
I think that one is this:
http://www.sxoc.co.uk/vbb/showpost.p...&postcount=123
Can you get hold of the boost versus BHP variation of that graph (normally you get a set of graphs from DD)
Blatantly though to me, that boost spiked, so I suspect the 400 bit is relatively accurate, but that the 16psi on your graph isnt correct, it must have spiked beyond its held figure he was expecting to 20+ surely?
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
