Bike Carb List
Old Sep 30, 2008 | 09:38 PM
blk-Mk5-zs's Avatar
blk-Mk5-zs
Default Bike Carb List
Ive decided to go for bike carbs on my zetec, in a mk2 xr2, the manifold and carb choice are sorted, just need the rest of it...
heres what i can think of
Throttle Cable (can the xr2 one be modded?)
Regulator (im running an injection tank so just the injection to carb regulator?)
Vac Take Off...to the servo?
and esc management
anything im missing?
thanks
Old Oct 1, 2008 | 03:53 AM
Are they carbs or throttle bodies ?
Old Oct 1, 2008 | 06:48 AM
blk-Mk5-zs's Avatar
blk-Mk5-zs
carburettors
which will be ran with esc management from a 1.1 mk3 fiesta
i know throttle bodies will be better in the long run but ill be doing everything myself with the carbs on a budget of £200 (apart from a setup) which is a hell of alot cheaper than tb's, and if the fuel is too much ill go back to standard injection
the only cost will be to get the carbs setup at bogg bros for £80 the rest will be for parts,
thanks
mk3ste
Oct 17, 2021 10:09 AM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
sridgett
Oct 1, 2015 07:30 PM
Orion_Gav
Sep 29, 2015 04:50 PM
