Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Window won't work MK6 Escort Si
Old Sep 30, 2008 | 11:39 AM
Marshall76's Avatar
Marshall76
Default Window won't work MK6 Escort Si
Hi,
Just after some help please before I freeze to death, my drivers window stopped working the other night much to my annoyance, not sure what the problem is, the green light shows on the passanger side one but not on the drivers, it flickers when you bang it, but the window has just stopped working (half way up I might add).
Just after some advice on what to look for, bare in mind I am a completwe forest gump with anything technical.
Many thanks in advance.
Old Sep 30, 2008 | 09:44 PM
dangerousbrian's Avatar
dangerousbrian
switches go on those quite often..try a new 1
Old Sep 30, 2008 | 09:59 PM
craigos's Avatar
craigos
yeah they do or the wires under get dam and grubby
Old Oct 6, 2008 | 06:21 AM
bluescortcossie's Avatar
bluescortcossie
as said the switches often pack up
to get your window back up - pop the switches out and swap the plugs around (use the passenger side button on drivers side wires) then you can at least put the window up !
don't hold me to this though as its a good while since i was playing about with a mk6 but i am 99% sure the plugs are the same for both sides
Old Oct 19, 2008 | 07:41 PM
yellowsierra's Avatar
yellowsierra
Yes you are right dude, same for both sides. The switches are a bit of a bitch and just pack up from time to time which is why i carry a spare set in the love-box. Sometimes when mine go sticky, i just pop the cover of and reach under the switch to the wires and give it a wee wiggle and they work again.
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 16, 2015 06:38 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
