engine noise update!
Old Sep 29, 2008 | 09:15 PM
mechanic28's Avatar
mechanic28
Default engine noise update!
well had a little look at her tonight and noticed that the cambelt was not sitting right on the aux and bottom pulley so after struggling with the bottom pulley for 30mins(much swearing!!!!as i have only just cleaned and put cooper slip on it not more then 500 miles ago!!!)took the cambelt off and noticed there is some play in the aux pulley (slight in and out movement!)i have posted a video you cant really see the movement on it(crap pic!) but you can here the knock with the in out movement!so have i been lucky?or unlucky?
http://uk.youtube.com/watch?v=9uHPQyZkAf4
Old Sep 29, 2008 | 09:19 PM
KSA-Cossie's Avatar
KSA-Cossie
Lucky boy,rather that than a fooked bottom end.
LHD220Turbo's Avatar
LHD220Turbo
panic over then
i bet all of a sudden you like the car again
Old Sep 29, 2008 | 09:23 PM
mechanic28's Avatar
mechanic28
dont love it still lol!still not 100% sure its the problem to be honest but cant see it suppose to have any movement on that pulley!will try and get a better video tomorrow,problem is the new pumps are jsut as bad it seems!
Old Sep 29, 2008 | 09:31 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
under the aux pulley, there is a plate held on with 2 set screws, remove these, and remove dizzy and i think the shaft will come out and leave the oil pump drive in place.
maybe the locating plate is loose?
im sure there is a bit of movement in them....
Old Sep 29, 2008 | 09:35 PM
mechanic28's Avatar
mechanic28
that plate should be ok as i tightened those two flathead screws up when i had the engine out to replace all the gaskets
malkiemac3579
Jul 14, 2017 12:10 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Churtz
15
Aug 13, 2015 06:40 PM
track.focus'd
Aug 12, 2015 05:53 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
