Checking light bulbs
Im probably being thick here, but if you connect a bulb across the battery terminals it should light up?!
Ive tried it including an electrical screwdriver with test lamp, the test lamp lights up which means there is a complete circuit, but the actual bulb isnt?!
Ive tried it with 3 different ones now lol
I just want to check the actual bulb is working so i can rule that out of the problem
Dr. Ickxs
Sep 15, 2015 10:15 PM
... well my grandpa used to do it!
