53 Plate Focus - Air bag light
Old Sep 29, 2008 | 06:50 PM
robbo1289's Avatar
robbo1289
Exclamation 53 Plate Focus - Air bag light
Hi guys , ive just bought a 53 plate 1.6 focus , and the air bag light on the dash stays iluminated while ever i drive around , are there any common faults or do i need to visit a Ford dealer ,
many thanks
Old Sep 29, 2008 | 09:11 PM
105epwr's Avatar
105epwr
many thanks
your decent local garage should have sum sort of code reader either a snap on scanner etc and will read out the fault via the obd,replace the new part as ness,clear fault after-job done!
a code read will set you back 30 odd quid tho just to read out the fault.
Old Sep 30, 2008 | 06:52 AM
JonathanJ's Avatar
JonathanJ
The most common fault we get is the front crash sensor , as it gets all the weather , but the only way to be sure is to get somebody to , as 105epwr said , to read the DTC's present in the system and give you an idea of the faulty component , just make sure that the air bag pretensioner wires have not become disconnected under the seats is another quick easy thing to check
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Oct 9, 2015 07:38 PM
jaysoc1
Aug 20, 2015 08:18 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Old ford
Jul 31, 2015 06:50 AM
