B&M shifter problem
Sep 28, 2008 | 04:35 PM
B&M shifter problem
just fitted my shifter and now when i drive it vibrates like frig? this aint rite is it ? any one else had this problem
thanks jim
Sep 28, 2008 | 05:07 PM
any one? really pissed off
Sep 28, 2008 | 05:13 PM
check your mounts? that aint right no
Sep 28, 2008 | 05:27 PM
whay mounts? car was fine b4 shifter was fitted
Sep 28, 2008 | 05:50 PM
mine did that mate,put four rube tap washers under it where it bolts in
Sep 28, 2008 | 06:37 PM
what in between the car and shifter plate? the four bolts yeah
Sep 28, 2008 | 06:54 PM
yes mate thats what i used
Sep 28, 2008 | 07:20 PM
use some sort of rubber gasket mate between car and shifter base.saves a lot of vibrations
Sep 28, 2008 | 07:32 PM
ok cheers people. will try it
Sep 28, 2008 | 09:50 PM
I can't see the point in rubber mounting something that was not designed to be that way. These shifters are a little noisy. I bonded all the lower console together from behind and that stopped any vibration I had. My shifter is mounted with only the skinny little gasket that Ford originally fitted and I have no problems.
Put rubber between it and you give it the chance to move and take away some of the positivity the B&M gives you.
Sep 28, 2008 | 10:01 PM
Mine was really anoying me so i made a rubber gasket from a sole of a mans shoe ( a new thin rubber stick on sole, not a used 1) uesd the ford gasket as a template, works a treat.
Sep 28, 2008 | 10:02 PM
four tap washers wont make the change any diff and stops it from doing it
Sep 29, 2008 | 06:25 AM
Mine is bolted with the metal plate directly to the car no gasket at all, and its fine.
Sep 29, 2008 | 07:16 AM
Quote:
Originally Posted by
craigos
OK, so this is 4 tap washers between the shifter and the body of the car?
How about water getting into the car? Or are you saying that the positive boost pressure keeps the water out?
Sep 29, 2008 | 07:16 PM
ive had enough the car will be going up for sale . nissans are calling again. have to get it outta the garage
Sep 29, 2008 | 08:29 PM
if you still having probs bud gimme a call and bring it round ill take a look for ya.
you got them koni's on yet
Sep 30, 2008 | 02:12 PM
Sep 30, 2008 | 06:05 PM
sortedscort
yeah they are on m8 i think you should buy the car of me lol
Sep 30, 2008 | 06:07 PM
pm me a price just could well be interested lol
Sep 30, 2008 | 06:11 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
cameron2
Sep 20, 2015 04:30 PM
