Think my cam is worn?
Old Sep 27, 2008 | 11:24 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default Think my cam is worn?
hi on low boost 6psi the car is fine, when i go on high boost 16psi anf floor it it misfires when comin on boost, but if im half throttle it is fine? any ideas.....
Old Sep 28, 2008 | 06:22 AM
Badman38's Avatar
Badman38
your car is blowing out the spark on the plugs smaller gap or new plugs.
sean
Old Sep 28, 2008 | 08:28 AM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
i have had it set up by harvey gibbs mate, was running fine until yestreday new plugs etc
Old Sep 28, 2008 | 01:17 PM
mark2's Avatar
mark2
did it start having the problem after fog or rain
its gotta be worth seeing if you have an airleak
if plugs are fine remove leads and check and spray wd 40 over connection cant hurt it
mark2
Old Sep 28, 2008 | 01:31 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
well when i drove it on a friday it was fine
drove it on a saturday thats when it done it?
Old Sep 28, 2008 | 01:46 PM
mark2's Avatar
mark2
does sound like electrical side of things give leads and plugs ago but check for air leaks go over all the joins and checking tightness
if cam was worn it would of shown up slowly not ok one day and not the next, does it rattle a bit is the cam old can get very noisey after 20k or a lot less on a 285 t2 are tappets ok
mark2
Old Sep 28, 2008 | 01:48 PM
gup's Avatar
gup
when it pops and bangs on high boost does your rev cointer drop at all
Old Sep 28, 2008 | 02:03 PM
The Youth.'s Avatar
The Youth.
presume it's an rst.
check the ht side of things, particularly the dizzy cap and rotor arm,
steve
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
