5th Gear Cog
Old Sep 27, 2008 | 07:38 PM
Pat's Avatar
Pat
Default 5th Gear Cog
I stripped my gearbox today to see what damage i have done on my S2 ERST.. 5th gear is completely mashed other than that its fine..
My question is where could i get another cog from?? Some people have said to put a diesel one on.. is this true...
Fords dont sell the cogs on there own... Only other way i guess is a second hand box..
Old Sep 28, 2008 | 05:09 PM
105epwr's Avatar
105epwr
are you sure everything else is ok?i did the same and a smashed 5th gear was only the start of it all!!!!theres a place called GEARS which advertise in the pf mag he is very helpful and sells stuff seperatly
Old Sep 28, 2008 | 05:38 PM
mk3cable's Avatar
mk3cable
i striped a knacked box down the other week (main shaft) the cogs are lying about at work if you put up a pic of the ones that are gone ill try and sort them out for you and post them, there gonna go in the bin other wise.
matt c
Old Sep 30, 2008 | 06:58 AM
JonathanJ's Avatar
JonathanJ
I have got a stripped ERST box in garage if you want standard ratio or might have a slightly different one either way if you want longer or shorter 5th ,
Let me know as I dont want it as staying standard ratios in my FRST
Old Oct 1, 2008 | 05:51 PM
Pat's Avatar
Pat
Default Cogs
http://img.photobucket.com/albums/v4...r/S8300073.jpg
As you can see, i need them two cogs...
tankybaby66
Feb 6, 2016 02:24 PM
Chas
Oct 5, 2015 07:13 PM
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
