Serious question about induction
Not a dig in peoples preferences but how much does an induction kit cause you in bhp terms if you have to fit one as matter of space or because you like the noise. The heat factor does play a part, but to what degree? I fitted one on the Beemer for a comparison and it sounded like a Ferrari, but noticed a significant difference in performance, without a cold feed I may add, but none the less it was rotten to drive especially over 80mph
James a good example is a Mk2 Golf fitted with a VR6 engine witch came along to a RR day at AVA. It lost 11BHP @ wheels. Or gained 11bhp when the aditional air duckt(additional fan) was fed directly to the Filter.
Originally Posted by B8
James a good example is a Mk2 Golf fitted with a VR6 engine witch came along to a RR day at AVA. It lost 11BHP @ wheels. Or gained 11bhp when the aditional air duckt was fed directly to the Filter.
doesnt it depend on all the pipework etc aswell?
as the 57i kit gives a replacement pipe etc that prob gives less pressure disturbances and the like
i may try change mine back on my zetec see what happens.
