turbo
Old Sep 25, 2008 | 10:07 PM
michaelward's Avatar
michaelward
Default turbo
does anybody no how to fit series 2 turbo on to a series 1 engine because of the water feed pipes for the turbo
Old Sep 26, 2008 | 05:48 AM
JesseT's Avatar
JesseT
What I would do and have done:
Just disconnect the metal pipes from the turbon and forget there ever were some.
More approved answer:
Cut the top and bottom radiator water hoses and install T-pieces to connect to the turbo. Also S2 top hose can be directly used, but the bottom hose is different because the water pump inlet is different
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
