sapphire4x4 oil separator
i am in the process of fitting an oil separator to my sapph the cam cover has been drilled the kidney box has been removed and i will be using the original oil return port the kidney box was connected to as the return from the sdeparator.there was a pipe that went fronm the plenum cover to the kidney box as there is now nowhere to connect this to do i just block it off.also there is nothing else to that i have to do that i am aware of am i right in thinking this?
yes that is the separator can i connect the return pipe to the original return just in front of where the original kidney box sat if not do i haveb to block off that outlet and connect it to the turbo side as you say.also do i need any sort of flame trap anywhere?
deathrider666
Sep 28, 2015 06:12 PM
