Headlight Wiring help, Rover Metro
Old Sep 25, 2008 | 07:06 PM
ickey818's Avatar
ickey818
Default Headlight Wiring help, Rover Metro
Hi,
I know it's not a Ford but my next door neighbour has just been round asking if I could have a look at his daughter headlights on her Rover Metro.
Basically her boyfriend has wired in a set of extra driving lights but instead of installing a relay and associated wiring he has just twinned the new lights into the feed to the main headlights and then earthed the driving lights to the body. Apparently when he turned the lights on everything worked for a few minutes and then it all went out.
So far they have checked the fuses in the drivers compartment, the relays and have changed the column stalk but lights still won't work. Have checked the fuses myself tonight and all of them look ok including the larger fuses under the bonnet. Going to have a look at the relays at the weekend.
Can anyone else suggest anything else that could of blown or burn't out that I should check?
Any help would be appreciated.
Old Sep 25, 2008 | 07:15 PM
James998's Avatar
James998
I'd be inclined to check the original wiring, I can't imagine it's all that great, and the extra load of additional lights can't really help.
Old Sep 25, 2008 | 07:18 PM
ickey818's Avatar
ickey818
Have just been reading on a Rover forum that the original wiring in the fuse box is pretty rubbish, looks like a few people have had similar issue's even without additional driving lights been added into the system.
Will take fuse box out at the weekend and see if any of the connections have gone.
Old Sep 26, 2008 | 05:59 AM
The best thing would be to start at the beginning with multimetre, and just follow current along it's route, then it will be very clear where the break/stoppage is.
Nov 1, 2015 06:53 PM
AJC
Oct 1, 2015 06:47 PM
Steve Escos
Oct 1, 2015 06:57 AM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
