Electricians.. How come my dyno fan switch has sooo many wires?
Old Sep 25, 2008 | 03:24 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Electricians.. How come my dyno fan switch has sooo many wires?
It's a single fan (quite large) and the control box is a mass of wires, why?
Old Sep 25, 2008 | 03:41 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
It's probably an invertor/speed controller?
Ours is a box of quite considerable size, with 2 cooling fans, so I'm not surprised to see that.
Old Sep 25, 2008 | 03:48 PM
frank wilde's Avatar
frank wilde
looks like a 3 phase motor star delta starter to me complete with a isolater and start/stop push buttons. The star delta starter is a method of reduced voltage starting used on motors over a certain size to reduce mechanical enertia (spelling) and electrical inrush + it has protection for the motor
Hope this helps
Kind regards Frank
Old Sep 25, 2008 | 03:54 PM
GARETH T's Avatar
GARETH T
franks right,, its a star-delta starting motor!
Old Sep 25, 2008 | 04:04 PM
leecavturbo's Avatar
leecavturbo
In english your fan is so power full it cannot just start as a normal motor would (genuinely)
Old Sep 25, 2008 | 04:06 PM
Martin-Hadland
Cooool Thanks for the explanation guys. Good job I didn't wire it into a 3 pin socket then..
Old Sep 25, 2008 | 04:13 PM
GARETH T's Avatar
GARETH T
if that box ever breaks,,, rip it off the wall and buy a soft start! much nicer way to start a large motor!
Old Sep 25, 2008 | 04:17 PM
Rab's Avatar
Rab
Fucking superstar........
I can also see a latching contactor, presumably so you don't have 3-phase going through the 'on' swtich.
Old Sep 25, 2008 | 04:23 PM
GARETH T's Avatar
GARETH T
i can see the main, star and delta contactor, and a timer to control the transition point between star and delta
Old Sep 25, 2008 | 04:24 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Proper snakes orgy in there!
Old Sep 25, 2008 | 04:32 PM
leecavturbo
agree with everything gareth said , haven't a clue what rab is on about.
soft start is nice but Ł500+ just for the starter
Old Sep 25, 2008 | 04:33 PM
KSA-Cossie's Avatar
KSA-Cossie
Looking at the overload it doesn't seem a very big motor,what kilowatt is it ?
Old Sep 25, 2008 | 04:38 PM
GARETH T's Avatar
GARETH T
more like 200 quid LOL
Old Sep 25, 2008 | 04:39 PM
leecavturbo
i use telemacanique ŁŁŁŁŁŁŁŁŁŁŁŁŁŁŁŁŁŁ
Old Sep 25, 2008 | 04:40 PM
KSA-Cossie's Avatar
KSA-Cossie
Better off with omron or klockener moeller m8.
Old Sep 25, 2008 | 05:24 PM
dojj's Avatar
dojj
Resident Wrestling Legend
i can just picture martin doing this
http://www.lionel.com/products/Produ...11000_3489.jpg
Old Sep 25, 2008 | 05:43 PM
pee vee's Avatar
pee vee
yeah... but when the cost of the rolling road is many thousands...
stuff like that is just 'the little bits you have to have'
Old Sep 25, 2008 | 05:53 PM
Martin-Hadland
7.5 kw, just ran it for the first time It's on lockable castors which I forgot to lock and once started it was off on it's travels big time!!! It's also re distributed every bit of dust in the shop and blown over ladders and other stuff in the way!
Old Sep 25, 2008 | 05:56 PM
Red16's Avatar
Red16
Are you doing your own mapping or is someone operating the r/r for you?
Old Sep 25, 2008 | 05:57 PM
Martin-Hadland
Going to be doing it all myself.
Old Sep 25, 2008 | 05:58 PM
KSA-Cossie's Avatar
KSA-Cossie
Aye it'll blow skirts up no probs lol.
GARETH T's Avatar
GARETH T
ever action has an equal and opposite reaction LOL
Old Sep 25, 2008 | 06:01 PM
Martin-Hadland
As said in the film 'snatch'
Old Sep 25, 2008 | 06:02 PM
mrjenrst's Avatar
mrjenrst
So do we but there free!
Just go into store's and get one out
Old Sep 25, 2008 | 06:06 PM
leecavturbo
if anybody doesn't make the numbers they hoped for they won't beable to blame the fan
Old Sep 25, 2008 | 06:57 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
They´r right, a softstart is a much better system, but this is actually build because it will overload the fuses and powerlines in no time when it starts up, so it will start in star delta and save you from building a HUGE power outlet.
7500watt is about 32 amps and the start current is maybe arr 150amps (cant remember the right formular to this) if it starts up normally, but this system makes it to start up with maybe a third of that.
Old Sep 25, 2008 | 06:58 PM
GARETH T's Avatar
GARETH T
7-10 times FLC is a good guild to starting current!
fans are terrible as they need alot of torque to drive, as the load is never disconnected!
Old Sep 25, 2008 | 07:33 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
are we in the middle of an electrical nerd off on PF?
Old Sep 25, 2008 | 07:43 PM
focusv8's Avatar
focusv8
No,
But check that the overload is set to approx 0.58 F.L.C. (set on the small yellow dial under K.1M)
Old Sep 25, 2008 | 07:45 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
I reckon so! Great reading, so much knowledge on here, and what this place should be like
Old Sep 25, 2008 | 07:46 PM
leecavturbo
were all secretly working for reyland as PR nerds
Old Sep 25, 2008 | 07:50 PM
GARETH T's Avatar
GARETH T
i always set them to 100% running current,, as tested once the unit is operational!
Old Sep 25, 2008 | 07:58 PM
Martin-Hadland
Originally Posted by focusv8
No,
Is that directed at me? If so I will check
Old Sep 25, 2008 | 08:01 PM
J1mbo's Avatar
J1mbo
B1mbo
what ecu's you gonna be mapping ? any/all ?
jim
Old Sep 25, 2008 | 08:05 PM
Martin-Hadland
jim
Mainly Pectel as that's my ECU of choice but I will work with others.
Old Sep 25, 2008 | 08:06 PM
KSA-Cossie's Avatar
KSA-Cossie
No,
The 0.58 depends on how your s/d starter is laid out though m8.
Old Sep 25, 2008 | 08:11 PM
westus1's Avatar
westus1
3 pin plug's fine for it,
just remember to use a 13amp fuse, it'll blow a 3amp lol
Old Sep 25, 2008 | 08:13 PM
J1mbo's Avatar
J1mbo
B1mbo
cool !
Old Sep 25, 2008 | 08:14 PM
GARETH T's Avatar
GARETH T
you are right of cause, if the thermal overload is on the delta contactor it should be set to 0.58 FLC,
i dont really like doing this method, as generally everyone over rates there motor size when designing a system and the motor never runs anywhere near FLC, so i always test!
Old Sep 25, 2008 | 08:16 PM
danneth's Avatar
danneth
TORQUE!
