series one fuel pump carrier???
struggling to find a new carrier and bracket for my underbody resto as its the only bit i cant source.any ideas guys.tried the usaul like fordparts etc.any body got one?cash waiting.cheers
New! Complete Petrol Pump Bracket ready to fit, Fits S1 & S2 RS Turbo
At last no more searching breaker's yard's trying find a good second hand fuel pump bracket for your S2.
AS has brought out their complete fuel pump bracket replacement made from high grade stainless steel once fitted no more corrosion problems.
See HERE
I bought the carrier, NOT the complete unit, and the carrier DID NOT fit the S1 base shown above.
Hoever, if the whole thing shown above was purchased, then there is a very good chance it would fit. You will need to speak to them to double check, also, make sure the S1 fuel pump afits inside, are they a narrower pump on the S2??
How recked is your base mate, the bit with th rubber attached??? if this is ok, clean it up and spray it, then look at making or having the arched carrier fabricated.
lot of it totally knackered mate so its a complete replacement
JK12
33
Apr 26, 2021 12:09 PM
