High pressure Header tank caps
Old Sep 23, 2008 | 07:40 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Default High pressure Header tank caps
Got a pace header tank on mine. The cap has started to release pressure so where do you get a high pressure cap from? I'm sure pace just supply the normal one
Old Sep 23, 2008 | 07:56 AM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Rich,
Mines a pace tank & that accepts a standard Cossie cap, so speak to Alex & get a nice black one !!
Jus hope it is the cap !!
jb
Old Sep 23, 2008 | 07:58 AM
R4N SS's Avatar
R4N SS
i had a forge header tank with std cap and never had any problems.
Old Sep 23, 2008 | 08:02 AM
Smit's Avatar
Smit
The 60ft Launch King
I've got a replacement cap on my bailey and releases pressure @ 98oc iirc
Steams rather well when your going down the back straight on a track day!
Does a normal yellow/black Ford cap fit it JB?
Old Sep 23, 2008 | 08:07 AM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Bailey use a VW cap on their's Mk 2 Golf I think ??
Pace/Forge use the original Ford caps & Alex does a really nice black one !! better than the yello that stays yellow for like 10 seconds after removin from box !!
Your cap's might jus be old ?!?! You can hope
jb
Old Sep 23, 2008 | 08:12 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Rich,
Are you seeing high temps? It may be worth hooking up a pressure gauge to your cooling system, just T of one of the small pipes. I hope it's the cap but it's normally h/g issues that causes your symptom.
You could do a sniffer test in the header tank, that might be easier.
Old Sep 23, 2008 | 08:17 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Originally Posted by martin-reyland
Rich,
Which goes hand in hand with mega-boost .
Old Sep 23, 2008 | 08:21 AM
CossieRich's Avatar
CossieRich
It only when i switch the car off not when im driving? Does that make a difference? The cap is 6 years old
Old Sep 23, 2008 | 08:24 AM
CossieRich's Avatar
CossieRich
And Martin. No not hight temps. fan always comes on at 93 i think.
Old Sep 23, 2008 | 08:34 AM
Martin-Hadland
That does sound better!! Normally when it's H/G/F you will get water pushed past the cap when it's on boost, if that's not happening you might be lucky and it is just the cap. Get a new one on and let us know.
Old Sep 23, 2008 | 08:35 AM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
+ 1
Old Sep 23, 2008 | 08:57 AM
Mike Rainbird
Caraholic
I have a new standard yellow one?
Old Sep 23, 2008 | 01:09 PM
CossieRich's Avatar
CossieRich
1) how much
2) can you paint it black please
Old Sep 23, 2008 | 01:11 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Vauxhall ones are black, and have a built in sender in them for a level light.
Old Sep 23, 2008 | 01:13 PM
CossieRich's Avatar
CossieRich
And it will fit a pace header tank for a cossie Chip?
Chip's Avatar
Chip
Assuming its the same thread that the bailey one uses, then yes as I have one on mine.
Old Sep 23, 2008 | 01:34 PM
Ollie MK5 Turbo's Avatar
Ollie MK5 Turbo
The ford black tank cap are for high pressure. Alex has them.
Old Sep 23, 2008 | 01:38 PM
CossieRich's Avatar
CossieRich
Can you ask Alex how much please mate as i dont have his number
Old Sep 23, 2008 | 01:45 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Jus so ya know, Ford caps & Bailey/VW caps are different thread so wont fit
I did say speak to Alex like months ago !!
jb
Old Sep 23, 2008 | 01:56 PM
CossieRich's Avatar
CossieRich
it ok gents. All sorted thanks to Mike R. He has one laying around, my bailey turbo damper broke so i am paying for the replacement part on the damper and the cap comes FOC
Old Sep 23, 2008 | 02:20 PM
Mike Rainbird
Caraholic
It didn't break, it came loose and fell out while you were mapping .
Old Sep 23, 2008 | 02:54 PM
CossieRich's Avatar
CossieRich
Im telling you Mike, Deano did that hanger up the same as any other cossie
Old Sep 23, 2008 | 02:56 PM
Mike Rainbird
Caraholic
Okay have it his way, it exerted 7 tons of pressure and snapped it .
Chas
Oct 5, 2015 07:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
coscor86
Sep 20, 2015 01:21 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
