Fiesta Zetec S problem....
Old Sep 22, 2008 | 06:27 PM
cfoster's Avatar
cfoster
Default Fiesta Zetec S problem....
Bought the missus a Zetec S (Met.Black W plate with 61k on it) and have a couple of possible issues with it so thought i'd best ask on here!! The car does have full history and looks like its been well maintained.
Sometimes, intermittently when starting the car up you need to hold the key cranking the starter for a fair few seconds before it fires up into life. Sometimes it will start straight away, other times it seems a real effort. Is this a common problem on these?? Not really sure what it could be, has full tank of juice, plenty of battery crank etc. Could it be the plugs?
Secondly sometimes the alternator belt starts squeaking/whirring, not the usual white transit van squeal when applying the throttle but a constant whirring noise when idling. Eventually it does go but surely not all zetec s's do this? Is it moisture in/on the belt causing this?
Any advice / ideas would be great.
Chris
Old Sep 23, 2008 | 11:24 AM
RichieST's Avatar
RichieST
First problem - Idle control valve, its a silver box thing that is fitted with 2 8mm bolts, its just after the throttle body, remove it and give it a thorough clean with carb cleaner, then a light oiling. Make sure the slider moves freely.
Next prob, its a knackered tensioner. Pretty straightforward to replace
Old Sep 23, 2008 | 12:19 PM
cjwood555's Avatar
cjwood555
Aux belt tensioners quite often fail / develop faults on these engines. Apparently there was a revision to them - you could try a focus part if you still get the problem with a new fiesta one.
Chris
Old Sep 23, 2008 | 04:59 PM
fonfe's Avatar
fonfe
Chris
surely a focus one wont fit as its a different zetec engine to the ones in the ZS fiestas?
Old Sep 23, 2008 | 05:12 PM
cfoster's Avatar
cfoster
excellent cheers guys, i'll get a tensioner ordered as well as a belt. Are the tensioners expensive?
Rich170 - is the ICV this mate?
Chris
Old Sep 23, 2008 | 05:42 PM
Tank Mike's Avatar
Tank Mike
yes it is
Old Sep 23, 2008 | 06:47 PM
Graham88's Avatar
Graham88
I have the same fault about having to crank the car for a while sometimes but sometimes it starts straight away. I made a topic about it a while ago but none of the solutions worked.
Mine's a 1.4 MK6 Fiesta, could it be the ICV too? Car is on 90k now
Old Sep 23, 2008 | 07:38 PM
RichieST's Avatar
RichieST
The engine in the early 1.6 focus is identical to the fiesta ZS one
Yes, thats it, remove two bolts, be careful to recover the seal, blast all the crap out with carb cleaner, then a light re-oil to make sure its all clean and operating smoothly
Old Sep 23, 2008 | 07:52 PM
JamesH's Avatar
JamesH
Tensioners are VERY expensive
Old Jul 24, 2013 | 08:22 PM
Melon_hed's Avatar
Melon_hed
I have a similar problem. I have a 2002 fiesta zetec s and
Sometimes you would have to crank hard to get it started, but this morning I went to and its not even ticking over? When I turn the key it's silent. Could this be the idle valve like you said or the starter motor? Would really appreciate any help you guys can give?
Old Jul 24, 2013 | 08:25 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Holy thread revival, Batman!
Does it click when you turn the key? If so, starter's dead.
Old Jul 25, 2013 | 05:17 AM
Melon_hed's Avatar
Melon_hed
No it doesn't even click or make a sound at all. But it jump started?
Mark_
40
Oct 2, 2015 04:40 PM
SMILER258
Sep 28, 2015 09:04 AM
Marv888
Sep 26, 2015 03:44 PM
