What suspension you got,how low?does it rub? looks good.
Yeah i'm interested in this question, cos i run 17 205/40's and they rub on full lock and if i go over a bump too quick! (but i think my suspension is fucked!)
its on a spax spx adjustable kit little bit of rub on the back arches so ill trim them when i get round to fitting the series 1 arches that are sat in my garage lol
as for the brakes its on cossie discs and calipars up front with drilled and grooved discs
I'm buying exactly the same Spax setup myself! Could you put a pick up of it side on please? So i can see just how snug they look in the arches!
Do they rub even with the shocks adjusted up real hard?
Thanks mate!
here you go mate hows this ?
she is sat in a slight dip here only noticed after cause the other rear arch is slightly lower
