saff 2wd misfire
Old Sep 22, 2008 | 12:51 PM
rigdoctor's Avatar
rigdoctor
Default saff 2wd misfire
hi can anybody help me please ive got a 2wd saff stage 1 tune seems to have developed a misfire just under 1 bar boosti have put new plugs in its not so bad now but still misfires a bit further up the revs.At a guess i,d say its the ignition coil but not 100% sure feedback would be much appreciated thanks
Old Sep 23, 2008 | 04:25 AM
stevecossy's Avatar
stevecossy
What gap have you at the plugs? as if std gap then maybe ya blowing the spark out, try0.6 or 0.7 ish.
Cheers steve
Old Sep 23, 2008 | 05:37 AM
What plugs are you using ?, if you have not already fit a group a coil, as with this and some AGPR12PP8 plugs you will find it drives much better, especially low down.
It could also be leads if a bit dodgy.
mark r
Sep 29, 2015 07:27 PM
cossie330
Sep 27, 2015 04:13 PM
DavidK
Sep 27, 2015 02:55 PM
ajamesc
Sep 27, 2015 02:25 PM
Russ Payne
Sep 25, 2015 08:29 PM
