actuator setting
Old Sep 21, 2008 | 06:26 PM
supermanrs's Avatar
supermanrs
rs turbo newbie
Default actuator setting
ive just bought a forge actuator and im unsure of where to set the actuator bar at?? can anyone help??
Old Sep 21, 2008 | 08:59 PM
jammy86's Avatar
jammy86
put it on by about 10mm and make sure its locked using the nut (mine fell off recenlty cause it wasnt locked well enough). Stick it on the car and see what boost it holds, then shorten it by 2 turns and see how much it holds. hopefully it'll add boost at the same rate per turn, but it'll take at least two attempts to find out how much it increases per turn.
What is the actuator as a -31 should hold 5psi when wound out fully, and a -34 should be 11psi.
JAmes.
Old Sep 22, 2008 | 02:24 PM
supermanrs's Avatar
supermanrs
rs turbo newbie
im not sure what it is as i bought it second hand, i now its ok as i can hardly move it when i pull on it but my old one i can easily pull all the way out with 2 fingers and it only made 5 psi with the bar wound fully on!
Old Sep 22, 2008 | 04:27 PM
jammy86's Avatar
jammy86
If it seems quite strong its probably a -34. Try the method above for setting your boost.
JAmes.
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
