boost hoses
Old Nov 10, 2004 | 10:28 AM
sf's Avatar
sf
Default boost hoses
when using the amal valve, where does the turbo and actuator hose go to, top or middle of amal valve?,
can u also put the bleed valve in line wi the actuator hose going to the amal valve?
Old Nov 10, 2004 | 04:59 PM
krisberic's Avatar
krisberic
Personaly i would run your car without the amal valve and run the hose from the compresser housing to the actuator with the bleed valve in line. If u havent got a boost gauge then get one cos u can make sure u run the right amount of boost. Mine works fine this way.
Old Nov 10, 2004 | 06:00 PM
Stoo's Avatar
Stoo
Tha Amal valve is marked im sure.
W=Wastegate ect ect
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Russ Payne
Sep 25, 2015 08:29 PM
