No speedo?
As above, i`m trying to fix my mates car. The speedo don`t work at all so i took the clocks out and the cable is connected properly. So i`ve checked the cable by putting a cordless drill on the gearbox end of the cable, and it works. Just doesn`t work when attached to the gearbox...
Anyone know what the problam could be...?
Many thanks, Ed.
Many thanks, Ed.
mate, I had this once, the cable goes into a plastic think on the box iirc, this can wear like to an apple core shape so isn't getting contact and so not turning the cable when driving.
There is some sort of pin to pull out and then retract this plastic cylinder thing out and change it.
Worked on mine, can be a b*stard to get that cyclinder out.
You want one of these
http://cgi.ebay.co.uk/Ford-Escort-RS...3286.m20.l1116
im sure ford still do them (and cheaper)
Thanks for the info, i will look into it in the morning and see how hard it is to change. Will also take a trip to the local Ford dealer...
Anyone changed one recently?
Escortdriver1
Jul 31, 2015 02:36 PM
