New shocks all round, anything else to replace?
My front shocks are a bit worn and need replacing so i'm getting a full set of shocks and springs from Fords, stock permitting!
Is there anything else I should replace front and rear?
Thinking all the bushes would be a good start, anyone else got any advice?
Cheers,
Lee
Cheers,
Lee
Spring cups, bearings, top mount rubbers, check your ball-joints as they wear quite quickly, also the fron ARB bushes are rubbish and this ones I wouldn't rreplace with standard items, also check engine and box mounts....and the list go on
Cheers for the advice guys, think i'll stop at suspension parts unless anything else needs replacing!
Heres what i'll definately replace:
shocks
Springs
Spring cups
bearings
top mount rubbers (again!)
bushes (again, last lot of polys were creaking)
standard rear beam bushes
anti roll bar
anything else i should do?
shocks
Springs
Spring cups
bearings
anti roll bar
krypton
Sep 23, 2015 07:29 PM
NC53
Sep 13, 2015 03:05 PM
