series one fuel relay help please...
hi, anybody know if its possible for the fuel relay to be working fine on a series one but not powering the pump? ive had the top off the relay and its working how it should but not making the pump work, ive ran wires straight from the pump to the battery and it fires up first time so i know the pumps ok, now before you say it must be a faulty relay i have another issue first, the black relay next to the fuel pump relay is the fuel relay module(im assuming this powers the pump relay) but im not sure if i have the correct relay fitted so would anybody be kind enough to tell me the part number on that black relay,its got a green plug going to it,also need to know if that relay has 4 or 5 connections? because the plug only has 4 and my black relay has 5 terminals?
by the way the relays were missing so ive never had the originals in the first place to compare..
really appreciate any help you can give on this..
jason.
jason.
