Rear suspension
Old Sep 17, 2008 | 03:36 PM
declan morris's Avatar
declan morris
Default Rear suspension
My right hand rear wheel ( drivers side ) on my 2wd saph leans in at the top and also is about 20mm back in the wheel arch. I changed the beam and the trailing arm but its exactly the same. Its unlikely that the beam and arm i changed are bent aswell so what could be the problem. Any info much appreciated as i dont want to buy another beam.
Thanks.
Old Sep 17, 2008 | 05:10 PM
siscossie's Avatar
siscossie
3-door moonstone
Talking rear end
Has the car been bumped at all measure the mountings and check they are in the correct possition, if they move it moves everything
Old Sep 17, 2008 | 05:31 PM
declan morris
If i find they are not in correct position can they be moved. If the mounting area is moved wont this move the diff forward and not line up with the bolting holes. Dont know if it has had a bump.
jessie_rs
62
Aug 6, 2019 09:27 PM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
truffleshuffle
Sep 10, 2015 09:35 PM
