Actuator
Old Nov 9, 2004 | 08:54 PM
K18NEO's Avatar
K18NEO
Default Actuator
Can you turn this up, as im only running 6 psi, boost controller 3 1/4 out, and boost gauge saying 6psi. No air leaks, ive sorted that, and i had this problem before i had the dump vavle on. No air leaks from what i can see!!
My question is, can you turn this up, to get more psi?
Old Nov 10, 2004 | 10:33 AM
adamS2RST's Avatar
adamS2RST
What exactly are you asking here mate, can you use the actuator to adjust the boost, yes. What is the boost controller bit all about?
Old Nov 10, 2004 | 04:40 PM
K18NEO's Avatar
K18NEO
oh, i still have a problem then...... its turned up.
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
