urgent help please wheres the idle adjustment screw on a escos small turbo
Old Sep 16, 2008 | 04:24 PM
dom123's Avatar
dom123
Default urgent help please wheres the idle adjustment screw on a escos small turbo
as tittle i can't seem to find it is there one?
cheers
Old Sep 16, 2008 | 04:33 PM
LHD220Turbo's Avatar
LHD220Turbo
assuming its the same set up as a 2wd saff, its a brass nut with a screw on the underside of the throttle body
undo the nut first in order to turn the screw to increase-decrease idle
Old Sep 16, 2008 | 04:34 PM
dom123's Avatar
dom123
i cant seem to see it as all the aircon crap in the way!!
Old Sep 16, 2008 | 04:41 PM
LHD220Turbo
should still be able to get to it, see on the pic below, it´ll be on the underside of the blue pipe coming from the intercooler into the throttle body
take the pipe off if its easier to find it and then replace
Old Sep 16, 2008 | 05:03 PM
dom123's Avatar
dom123
thanks for the pic mate but thats a different manifold i think, ive just taken the pipe off and the only think ive got is too adjust is the stop point on the throttle housing. has that one got the old sytle ivc valve?
Old Sep 17, 2008 | 06:00 AM
Aaroncast's Avatar
Aaroncast
Wink
-you Aint Got One!!!------your Ticking Over Fast Right??????--look For Idle Control Valve Sticking On Here To Sort It Out >>>>>>>>icv---!!!!
Old Sep 17, 2008 | 03:44 PM
dom123's Avatar
dom123
ive had a missfire, so i decided to close the plug gaps slightly now it doesn't idle it may be down to having coil pack that it doesn't like smaller gaps. I'm waiting for some new plugs now!!
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Graham S1
Technical essay Archives
Aug 24, 2015 03:58 PM
IAN RS2k
Aug 18, 2015 07:51 PM
turbobill
Aug 9, 2015 05:21 PM
