Engine cutting out.
Old Nov 9, 2004 | 04:14 PM
krisberic's Avatar
krisberic
Default Engine cutting out.
I have a s2 RST and have a slightly annoying fault. when the car is at normal temprature, and i start to accelerate, say from a junction when i lift off the throttle and press the clutch in the revs waver between 850 to 1000 rpm and then cuts out. It also does it on over run when approaching a stop. Does any one have an idea.
Old Nov 9, 2004 | 08:30 PM
phil robson's Avatar
phil robson
has it got a dump valve?
Old Nov 9, 2004 | 08:42 PM
K18NEO's Avatar
K18NEO
That shouldnt make a difference if its a sealed dump vavle?
I had the same problem on my cvh 1.4 before i had the turbo lump, you find yourself coming upto lights, pressing both the brake and the eccelerate together, cuz if you do this, it dont cut out .. am i right?
Old Nov 10, 2004 | 04:51 PM
krisberic's Avatar
krisberic
It has got a baily piston type with the twin piston type thingy.
Old Nov 10, 2004 | 07:23 PM
phil robson
check the spring hasn,t snapped at the top of the valve,this happened to me mates,what happened was the spring snapped and got stuck between the piston and the casing causing an air leak,check for air leaks elsewhere also
Old Nov 12, 2004 | 05:26 PM
krisberic's Avatar
krisberic
I have taken dump valve off and it still has the same problem cant seem to find any air leaks any where. any ideas any one.
Old Nov 12, 2004 | 05:32 PM
Muska's Avatar
Muska
i hadthe same problem on my old rst, it needed a set up. is your car chipped?
Old Nov 12, 2004 | 05:39 PM
krisberic's Avatar
krisberic
Not as yet, ive got a funny feeling it might be over fuelling as it likes a drink, might av to get a diagnostic check done.
Old Nov 16, 2004 | 03:20 PM
sufsRS's Avatar
sufsRS
their is no diagnostic porn on an rst is the
Old Nov 16, 2004 | 05:15 PM
Moonie's Avatar
Moonie
When i rebuilt my engine my car was doing the same, turned out to be the fuel mixture (too weak/lean). Adjusted the mixture now its fine.
gchristophi
Aug 31, 2015 10:36 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
