Escos Parts 200 Block, Head, Clocks + Loads Of Odds & Ends
Old Sep 13, 2008 | 04:18 PM
jacko996's Avatar
jacko996
Default Escos Parts 200 Block, Head, Clocks + Loads Of Odds & Ends
having a clear out and need to get shot of all these bits.
200 block/complete bottom end, inc. rods, flywheel, sump etc SOLD
4X4 head complete with cams etc. Measures 138.55 £Offers
Cam cover with breather £55
70mm Throttle body. Brand new never used. £140
4X4 Plenum £SOLD
Escos banana pod clocks £50 SOLD
Dash clocks cluster £125 SOLD
Clock / Temp gauge £90 SOLD
2wd exhaust manifold inc trousers £50
Standard pedal box £40
standard acctuator
4X4 manifold, has 1 small crack £30
2wd sump £30
Ignition coil
Standard cam pulleys
2WD water pump
2 WD crank shaft pulley £45
throttle body with idle control valve £50
2WD thermostat housing
Not too sure how much some of these parts are worth, so sensible offers considered.
1 damaged valve, and a few marks but nothing serious.
Sensisble offers,
70mm Throttle body. Brand new never used. As supplied from M Rainbird www.randbmotorsport.co.uk/shop/Parts.asp?ID=6
£140
Standard pedal box
standard acctuator
2wd sump. Excellent cond apart from sump plug needs helicoil.
Ignition coil
2WD water pump
Any sensible offer will secure
Old Sep 13, 2008 | 04:41 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
pm me a price for rocker cover please delivered
Old Sep 13, 2008 | 05:26 PM
bigpower's Avatar
bigpower
does the temp clock work and light up!
Old Sep 13, 2008 | 07:04 PM
tan's Avatar
tan
You have pm, thanks
Old Sep 13, 2008 | 10:22 PM
westus1's Avatar
westus1
prices please for the rocker cover
4x4 inlet manifold
pm me if you dont want to advertise the price for it all
Old Sep 14, 2008 | 09:40 AM
jacko996's Avatar
jacko996
Clock and light works fine thanks
jacko996's Avatar
jacko996
Hi
2wd manifold £60
4X4 manifold £40
cheers
Dave
4x4 inlet manifold
Old Sep 14, 2008 | 10:29 AM
louie1's Avatar
louie1
Default the lot
pm me a number and a price for the whole lot,what ever you have left cheers
Old Sep 16, 2008 | 07:02 AM
jacko996's Avatar
jacko996
Bump
Old Sep 21, 2008 | 10:37 AM
jacko996's Avatar
jacko996
I have been told the head has a small hairline crack between 1 spark plug hole and valve,
Apparently can be fixed.
So no sensible offer refused.
Old Sep 23, 2008 | 05:13 PM
RS SHAUN's Avatar
RS SHAUN
do you still have idle control valve mate???
Old Sep 26, 2008 | 10:25 AM
R5COS's Avatar
R5COS
temp clock as described mate works perfect free bump for ya
Old Sep 26, 2008 | 04:54 PM
RS Juto's Avatar
RS Juto
Pm'ed
Old Sep 27, 2008 | 09:28 PM
jacko996's Avatar
jacko996
Thanks Patrick, Glad you liked it
jessie_rs
11
Jun 3, 2019 04:57 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Zoggon
Aug 10, 2015 10:39 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
