Stage 3 cos co2 set up?
Old Sep 12, 2008 | 03:12 PM
stevev6's Avatar
stevev6
Default Stage 3 cos co2 set up?
As per title, am running a Ecos with a stage 3 setup. Been having a missfire lately after doing the conversion. Gone down the usual road of all ignition parts and sensors, gapping etc and still had it. A good firend of mine said what about the co2 adjustment on the back of the ecu?
I have tweaked this and seems to run a hell of a lot better. But what i want to know is what is the best setting for the co2 and how do i monitor it? Or know what to adjust it too ans its only a screw on the back of the ecu?
Any help guys?
Steve
Old Sep 14, 2008 | 04:58 PM
stevev6's Avatar
stevev6
Anybody????
Old Sep 14, 2008 | 05:00 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You set it up depending on the chip that's fitted.
Old Sep 14, 2008 | 05:15 PM
Stu @ M Developments's Avatar
PassionFords Creator
Also, your ECU shoudnt have a working screw on it, so your ECU isnt standard. It may have been downgraded.
Old Sep 14, 2008 | 05:22 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
That's a good point
Old Sep 14, 2008 | 09:52 PM
stevev6's Avatar
stevev6
Thats just confirmed what i was thinking. Thanks Stu. Time to book me in i think. The ecu is changed as the car was T25 and now running T34 with the full webber marelli setup.
Will call you Stu.
Cheers Steve
JK12
33
Apr 26, 2021 12:09 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
3doorcozmess
Sep 15, 2015 06:06 PM
3doorcozmess
Sep 7, 2015 01:32 PM
turbowag
Sep 3, 2015 08:07 AM
