Thinking of selling big brakes and grp a wheels
I'm thinking about putting me saph back to standard looking and selling the brakes, wheels and maybe the twin headlights.
The brakes are a bit hybrid which consist off 6 pot wilwood calipers and race spec pads, compbrake 330mm rotors, bells and hispec brackets. the calipers where recond and painted red and white then fitted with new pads and rotors and since covered about 300 miles only. The rotors and pads cost around £400.
The wheels are Revolution group a items 8x17" with 33 offset and the tyres are 215/40/17 and are only a few months old and have covered approx 500 miles.
The lightsare morrete and I also have a the under light trim without the wiper holes also in white.
Just thinking about it at the mo as I could do with some spare cash to spend on the house any offers welcome and then I will decide.
I will get some more pics up in the next couple of days.
Its a 4x4 looking for about £200 including the under light trim without the wiper holes in, its not in the pics but its painted to match I just never got round to fitting it.
Looking for £700 for the brakes and £175 for the lights also momo millenium wheel and boss £75, GGR twin piston dump valve as new only been on around 200 miles £70.
More parts will be listed soon let me know if anything of the car takes your fancy as I'm selling most of it and going to rebuild it at a later date from scratch.
Fully ported & polished to touring car spec
Inlet & exhaust manifolds ported to match
2wd Exhaust manifold for superior gas flow
Garrett T34/.63 stage 3 turbo (32psi) with –34 actuator
Mongoose 3” stainless exhaust with modified down pipe & 3 ½” tailpipe
WRC 3 layer metal gasket
ENGINE
200 Long studded block, fully lightened and balanced
7.5:1 Low compression pocketed pistons
2wd Lightweight flywheel
Fully assembled with ARP fastenings & Vibratechnics Mounts
FUEL/AIR & ENGINE MANAGEMENT
044 Group A fuel pump, Group A K&N Air filter
Escort motorsport fuel rail & regulator with Aeroquip lines & fittings
Bosch 403 grey injectors
3 Bar map sensor
Level 8 ECU*with baby Pectel & custom chip mapped by Interpro Engineering
Escort motorsport air/air, water/air intercooler with Pace charge cooler kit
Aquamist water injection controlled with S.E.C.S. engine data monitor
TRANSMISSION
Reconditioned MT75 gearbox with up rated bearings & quick shift
Alcon 6 paddle cerametalic clutch
CHASSIS
Koni adjustable shocks with Avo 25mm lowering springs
Alloy strut braces front & rear
Polybushed front & rear
Wilwood 330x32mm Front discs with 6 pot callipers & Rally Plus Pads, Goodridge hoses
WHEELS & TYRES
8x17 Revolution Group A alloys with 215/40/17 tyres
EXTRAS
Bailey - Header tank, Dump valve, Power steering fluid tank, Oil separator
Spec-R – Turbo Damper, Cam belt cover, Fuse box cover
Samco blue charge hoses & red coolant hoses
Clifford Concept full closure Cat 1 alarm
RS500 Front splitter, Morrette twin headlights, Clear side repeaters
ENGINE
3 Bar map sensor
TRANSMISSION
CHASSIS
WHEELS & TYRES
EXTRAS
Update I'm sorry to all the intersted parties but the monitor is now sold I wish I had another 10 to sell it is in demand however its sold to a local lad for cash.
All the parts that are needed to run the engine will start getting removed late next week so far there about 6 people wanting the fuel pump so I will post up when its off then it will be on a first come basis.
yes still for sale check out the link
https://passionford.com/forum/alloy-wheels-and-ice-for-sale/260573-8x17-group-a-revoloutions-with-tyres-less-than-400-miles.html
Already starting to regret it it Rob but its just not getting used, only done just over 300 miles in it this year after spending about £2500 on it stuff it didn't need so its time to get some back. I might still keep it with a lower spec or sell it complete with a lower spec, haven't decided yet.
At present I'm not removing any running gear due to storage complications I need to keep it mobile for now.
It might still get sold complete as Somebody is thinking of buying it but can't untill the end of next month.
