FRST relay help
Owners of FRST's will know the problems you have with the relay for the rad fan and heater with the melting relay/fuse tray.
At the moment im having problems with the relay not getting contact with one connector which obviously leads to problems. I have had to unscrew the tray and "adjust" the relay while sitting in traffic
Apart from changing the whole fuse/relay tray anyone got any good ideas on how to improve matters ??? im sure an auto electrician would charge a fortune!!!!
Its got to the position now that my relay doesnt work if its pushed right in, it has to sit at an angle, but i go over a bump (car lowered by 60mm!!!) and it can switch off
Any ideas gratefully received ..........
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
