Fuse box
Old Sep 11, 2008 | 09:26 AM
DAVE WRC's Avatar
DAVE WRC
Default Fuse box
Where is the fuse box located on a sierra saph cosworth is it under the bonnet or is there one in the car
Old Sep 11, 2008 | 09:51 AM
stevecossy's Avatar
stevecossy
Hi the main one is under the bonnet but there is also some relays under/in the dash.
Regards steve
Old Sep 11, 2008 | 09:53 AM
DAVE WRC's Avatar
DAVE WRC
Cheers mate i am looking for the location of the fuse for the foglights
Old Sep 11, 2008 | 10:11 AM
dojj's Avatar
dojj
Resident Wrestling Legend
it'll be a little white one under the bonnet box
the ones under the dash (glovebox) are for the abs,hot screens and other big power relays
Old Sep 11, 2008 | 01:30 PM
Fog light is number 17(20Amp) for front fogs.
Other fuses relays not in the main fusebox are abs relay/fuse(20a), pump(abs)30a fuel pump 15a, ecu 1a, located under glovebox area on metal bracket as well as air con(purple), some cooling fan, these are the main ones but there are more.
AJC
Oct 8, 2015 11:09 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
