Overboost function
Old Sep 10, 2008 | 01:42 PM
cossiesmølfDK's Avatar
cossiesmølfDK
Default Overboost function
Hi all
Can one of you help me out. My BT escos boost at 1,2 bar but without overboost.
My amal valve is the type with 2 connections on it. I can check the amal vavle by using 12 volt or? and how do i check if the ECU puts out the signal to the amal valve?
If i got i right the amal valve is the one that bleeds the air to the actuator during this overboost. Giving something like 0,2 bar in overboost
But when does the overboost kick in ? and what triggers it?
Hope you understand my problem.
Old Sep 11, 2008 | 12:29 PM
cossiesmølfDK
Nobody??????????
Old Sep 12, 2008 | 06:59 AM
Dave Henshall's Avatar
Dave Henshall
the overboost feature allows it to run ( on a std car ) just under 1 bar for a few seconds in the mid range when coming on boost, it then tails off to the std boost of around 0.6 bar.
Jim Galbally
Technical essay Archives
23
Sep 12, 2016 12:21 PM
YODI
Aug 30, 2015 01:12 PM
tomiii
12
Aug 18, 2015 08:40 PM
007
Nov 14, 2004 05:15 PM
