Adjusting linkage sticky???
Old Sep 10, 2008 | 01:25 PM
bloopeta's Avatar
bloopeta
Default Adjusting linkage sticky???
Since no one seemed to know that there was a "correct way" to adjust gear linkage, and were just using trial and error and good luck over good management, I have added it below for anyone whos interested. perhaps someone would like to add it as a how to sticky??
1) Select 4th gear.
2) Loosen the gearchange rod to selector shaft clamp bolt.
3) From under the car lock the gear lever in place by inserting a 3.5mm drillbit or allen key through the alignment hole on the bottom of the gearchange housing. (under car)
4) Ensure that the selector shaft is also in the corresponding 4th gear position by inserting a rod into the selector shaft hole, turning clockwise and pushing right in. (make sure you dont hit reverse)
5) Tighten the gearchange rod clamp bolt, remove the drift, rod and check the action of the gear change mechanism.
Old Sep 10, 2008 | 02:12 PM
Barry R's Avatar
Barry R
i have done loads of them you need to put it in reverse to do it on a 5 speed box
Old Sep 10, 2008 | 02:37 PM
bloopeta's Avatar
bloopeta
well I was told by a ford mechanic to do it that way and I did mine fine not half hour ago using the above method.
How do you do it reverse then?? because you can only lock the gear selector in 4th with a rod / allen key / drill bit, that is the way way ford made it. surely they didnt go to the trouble of making a hole there for nothing.
Old Sep 10, 2008 | 02:51 PM
Barry R's Avatar
Barry R
i was taught to do it in reverse my apologies
Old Sep 10, 2008 | 03:50 PM
addiction's Avatar
addiction
I always put it in reverse too!! and it always works!!
Old Sep 10, 2008 | 04:11 PM
bloopeta's Avatar
bloopeta
what ever works best for you m8, all I was trying to do was pass on some information I had found that may help people who didnt know how to do it. When I originally posted asking for help people were saying that they just kept trying and adjusting until they hit lucky.
Old Sep 10, 2008 | 05:40 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Handy info mate, thanks for the effort!
Old Sep 10, 2008 | 06:00 PM
nigel b's Avatar
nigel b
ive found reverse is the easiest way
Old Sep 10, 2008 | 06:30 PM
NUTS RuS's Avatar
NUTS RuS
I only use reverse and all the above is printed in the Haynes manual anyway im sure
But someone will need it so nice one
Old Sep 10, 2008 | 06:57 PM
bloopeta's Avatar
bloopeta
that was exactly my point m8, its written like that in the Haynes, and that is apparently how ford Used to do it when these cas were newer, and people were telling me its wrong!
Everyone has there own way of doing things and thats fine, but its nice to share something you have discovered.
yatta
May 21, 2016 10:31 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
coscor86
Sep 20, 2015 01:21 PM
