fuel pressure
Old Sep 10, 2008 | 11:26 AM
cossieboyIOW's Avatar
cossieboyIOW
Default fuel pressure
am i right fuel pressure should be just over 3 bar?? i put standard fuel regulator back on mine and it idles at around 2.2 bar is this too low??
Old Sep 10, 2008 | 05:48 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I thought standard fuel pressure was around 6bar on MFi!?
Old Sep 10, 2008 | 08:37 PM
cossieboyIOW
ah i didnt realise it was different its on EFI :P
Old Sep 12, 2008 | 01:43 PM
steven botes's Avatar
steven botes
I Run Mine At 2.5 Bar
Old Sep 13, 2008 | 08:57 PM
cossieboyIOW
cool thanks matey
Old Sep 13, 2008 | 09:38 PM
Oppliger Motorsport's Avatar
Oppliger Motorsport
Romain
Smile cossie standard fule pressure
Hi,the standard fuel pressure at 950rpm must be 3bar,if you run uprated chip and greens injectors its better to run on 3,2bar
in any case 2.2bar its not enough,you are probably running lean.
cheers
Romain
timsrs
Nov 13, 2018 11:48 AM
A.t.p
Oct 23, 2015 07:54 PM
SMILER258
Sep 28, 2015 09:04 AM
