wot oil do you guys use?
Old Sep 9, 2008 | 07:00 PM
L3 COS's Avatar
L3 COS
Default wot oil do you guys use?
hi, just wondering wot engine oil/grade, you guys use/recommend in your rs turbo,s also wot make of tappets you are useing as every set i buy seem to rattle there heads off after a few months!! lol.
Old Sep 9, 2008 | 07:52 PM
project rs's Avatar
project rs
miller oil 10/60 and cam and tappet combo of different sources, if you keep knackering up tappets are you swapping cam/tappets or just tappets and when doing both make sure you use plenty of lubricant and keep revs over 1500 for first 15 mins
Old Sep 9, 2008 | 08:03 PM
gaz s1's Avatar
gaz s1
Cant go wrong with mobil 1 motorsport, as mentioned you have to change the cam and followers together and if you still get major wear sounds like you have a oil pressure problem.
My power engineering cam has been in 9 years and still dont tick hardly at all
Old Sep 9, 2008 | 08:44 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Millers or Silkolene 15w/50
As already said. Cam and Lifters MUST be changed together or the older of the two will rip the other apart!
Old Sep 9, 2008 | 09:19 PM
L3 COS's Avatar
L3 COS
thanks for replies guys...
Old Sep 9, 2008 | 11:44 PM
Grandad racer's Avatar
Grandad racer
thought it was common knowledge rs turbos need fully synthetic oil, to cope with the heat .
Old Sep 9, 2008 | 11:59 PM
L3 COS's Avatar
L3 COS
yes i know that!! there are different grades of fully synthetic!
Old Sep 10, 2008 | 10:30 AM
idanrs's Avatar
idanrs
I think i can...
what do you guys say about liqui moly 10/40??
that's what Autodata says...
Old Sep 10, 2008 | 05:50 PM
Karlos G's Avatar
Karlos G
Balls Deep!
40's too thin when really hot and IMO 60 is too thick when cold (unless your track use only and need 60!).
Old Sep 10, 2008 | 05:52 PM
obrutsr09's Avatar
obrutsr09
Mobil 1 motorsport
Old Sep 10, 2008 | 09:06 PM
Tim's Avatar
Tim
Originally Posted by obrutsr09
Mobil 1 motorsport
Old Sep 11, 2008 | 02:41 PM
webby80's Avatar
webby80
millers or valvoline 10w60 mate
Old Sep 11, 2008 | 03:27 PM
T28 RST's Avatar
T28 RST
Ok then
Mobil 1 motorsport
Old Sep 11, 2008 | 06:22 PM
gee1599's Avatar
gee1599
tws motorsport 10w/60 only cos i get it cheep
Old Sep 12, 2008 | 06:03 PM
mark2's Avatar
mark2
mobile 1 15w 50 i get it for £28.50 from-------
Old Sep 12, 2008 | 08:01 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
I have been told by numerous people the fully synth is too thin.
I use vauxhall semi-synth. The two garage I go with my two cars both use this oil. One place is a Ford and RS nut and has many years experience with the RS range. He did a comparison check on the qualities of the vaux oil & the other major labels and found they are similar - except the vaux oil is a lot cheaper (around £15 for 5 litres) as they don't have the branding & advertising to contend with.
Been using this for around 5 or 6 yrs now with no issues what-so-ever. Best thing is, as it's cheaper overall, you can do earlier oil changes for the same money.
Latest poll I did on my site came back with semi-synth 5 or 10W.
Mobil 1 was considered too thin unless it's a new build engine.
Hope this following info is of use:
My vaux oil is 10W/40 Semi-synth. Oil properties are ACEA A3, B3, API SL/CF
Properties description found via here:
Oil Bible
ACEA are here European Car Manufacturers Association
codes relate to
A3 = high performance or extended drain
B3 = high performance or extended drain
API are these people API which seem what thatcham are to alarms.
So the SL/CF rating is S= Petrol car, L = the top grade (SL = old lettering, recently replaced with SM)
CF means it can be used on commercial vehicles also
Chas
Sep 21, 2015 08:57 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
c20tbo
Aug 17, 2015 10:19 PM
