RS Turbo running on 3 cylinders?
Old Sep 9, 2008 | 04:10 PM
g10ens's Avatar
g10ens
Default RS Turbo running on 3 cylinders?
My RS Turbo has developed a misfire and is not firing at all on cylinder 2, i have replaced the dizzy cap, rotor arm and leads but the misfire is still there. Would this indicate that the problem lies with the actual distributor?
Old Sep 9, 2008 | 04:23 PM
gup's Avatar
gup
is thier a spark at the end of the spark plug
Old Sep 9, 2008 | 06:30 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
could be fucked plug mine sone this changed the plug job done
Old Sep 10, 2008 | 09:25 AM
idanrs's Avatar
idanrs
I think i can...
Take the Plug out and check for spark in the plug,
If no spark then replace the plug and check again,
if spark is good then check compression in the cylinder with a pressure gauge,
if compression is o.k the could be a valve got blocked or something maybe covered in dirt and fuel is not getting to cylinder...
hope it's not you cylinder/piston/rings that will cause a compression issue mate.
if its a dirty valve sometimes a simple cleaner that you add to the fuel(like a BG44 etc'..) will help you clean the dirt off...
good luck.
Old Sep 10, 2008 | 09:09 PM
g10ens's Avatar
g10ens
Thanks for replys, it was the plug causing the problem - replaced it with one from my cossie and its running sweet as a nut now!
Old Sep 11, 2008 | 07:54 AM
idanrs's Avatar
idanrs
I think i can...
Good news !!
Matt Baxter
Sep 16, 2015 08:30 PM
ekjim
Aug 17, 2015 08:57 PM
Churtz
15
Aug 13, 2015 06:40 PM
Zoggon
Aug 10, 2015 10:39 AM
turbobill
Aug 9, 2015 05:21 PM
