System 2 1.9 Power Engineering
Old Sep 8, 2008 | 07:37 PM
320 bhp's Avatar
320 bhp
Default System 2 1.9 Power Engineering
Are They Any Good What Sort Of Power They Good For,ive Just Bought 1 And Thinking About Going Down The Cosworth Mangment Route?or A Will Be Ok On Mfi With Hybrid Turbo Front Mount Cooler Ect?
Old Sep 8, 2008 | 10:04 PM
homer j's Avatar
homer j
any type of EFi would be better than the MFi and will release more of the engines potential so if you can splash the cash and get a better management sorted out. as for the system 2 engine i've had no dealings with it so can't comment.
regards
Tom
Old Sep 9, 2008 | 08:36 AM
grayzo's Avatar
grayzo
grayzo
ring power engineering and ask for ian ball on 01895272111 he used to build them
Old Sep 9, 2008 | 08:48 AM
320 bhp's Avatar
320 bhp
thanks for that mate
Old Sep 9, 2008 | 08:56 AM
GUZZLER's Avatar
GUZZLER
Great engines around 1 bar of boost but they can suffer with the blocks cracking with high boost!
Old Sep 9, 2008 | 12:38 PM
mk3cable's Avatar
mk3cable
apparently! i run mine with 20psi and had no probs at all with cracking and also known other people on here running more than that. i have never actually seen or heard of the blocks cracking other than roumers.
Old Sep 9, 2008 | 12:49 PM
320 bhp's Avatar
320 bhp
what bhp did your make and what spec were you running efi or mfi thanks kris
Old Sep 9, 2008 | 01:30 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
I can confirm the blocks do crack under high boost, I used to have one in my car a few years back which did this. I also know other which had a cracked block
Some of the engines were also built by Vulcan engineering.
I would expect that GUZZLER has seen a few more system 2's than most people and have a balanced view on them
I would personally take a good 1.6 CVH over a 1.9 CVH any day and i've had both, including engines using the US block
ginner
13
Aug 30, 2015 08:40 AM
nick8saff
Aug 16, 2015 05:35 PM
marvin
Fiesta RS1800/RS Turbo
Aug 10, 2015 11:14 PM
Old ford
Jul 31, 2015 06:50 AM
