4wd cos oil pump/spray bar in a 2wd
Right what needs to be modified to make them fit properly?! i know the pipe/spray bar catches on the stainless plate inside the 2wd sump bit other than that what else needs modifying?! noticed the pick up pipe is very close to the bottom of the sump too so hope that isnt a problem?!
Cjeers
Cjeers
FlashRS
13
Aug 31, 2015 06:02 PM
