i was wrigglin my headlight relays as my lights were playin up, then wen i started the car, i sat in it while it warmed up a bit, n noticed my gauge hasnt moved all day since driving, does the temp gauge hav a relay or fuse? think i hav knocked sumart wen messin with the relays, any ideas cheeRs.
take the wire off the sender on the head, its to the right of the exhaust manifold one single brown iirc wire on it. earth it out onto the engine with ignition on and get someone to check the guage goes up to max, if so then the sender is faulty so replace! they are penny's.
