Siezed calliper on my mr2
Old Sep 5, 2008 | 11:05 AM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
Default Siezed calliper on my mr2
just failed mot on this can u free them up at all?? as a reconned one is £120! any help appreciated cheers Statey
Old Sep 5, 2008 | 11:06 AM
Adam.'s Avatar
Adam.
Its the rear offside btw
Old Sep 5, 2008 | 11:11 AM
LHD220Turbo's Avatar
LHD220Turbo
depends on how bad its seized
whip it off at have a look.
take pads out; push pistons back with a suitable tool, push foot on brake pedal and see if they move back out; repeat & repeat again if need be.
Old Sep 5, 2008 | 11:26 AM
Rab's Avatar
Rab
Fucking superstar........
Very common. www.camskill.co.uk do recons for 99 quid exhange. Don't waste your time trying to free it up, it will just start leaking and not work again, and you'll fail the MOT for not having brakes.
You can buy caliper overhaul kits and do them yourself if your handy with the spanners and have somewhere mega clean to work in.
Old Sep 5, 2008 | 12:03 PM
Adam.'s Avatar
Adam.
Thats the things just about to go on holiday next week so if i can fix it with out replacing it then sweet! if not will have to wait till i get back
Old Sep 5, 2008 | 12:24 PM
Rab's Avatar
Rab
You could try spraying a bit of WD behind the dust seals, then work the caliper in and out. But it'll more than likely leak afterwards, or not work at all.
s1cab
Jul 26, 2018 06:11 PM
Mark RS
Jan 13, 2016 06:56 PM
jason_nike
Aug 31, 2015 10:15 PM
YODI
Aug 30, 2015 01:12 PM
deleted
Nov 30, 2004 05:29 PM
