mot emissions prob
even with the cat removed it shouldn't be that high, sounds like another prob in there, did you see what the lambda reading was or the hc's?, as these often give away clue's as to another prob
check you HC, thats ALOT more important to tell you about the engine, ill bet its over 300, the limit is 200 BUT anything after 60 means a miss fire ect
cats are only there to assist the excess rather than do all the work
get it fixed
