Valve hitting pistons..urgento.
Old Sep 4, 2008 | 07:38 PM
OldDan's Avatar
OldDan
Default Valve hitting pistons..urgento.
Having a bit of trouble doing the cam timing on the fiesta.
Am I correct in thinking that if the valve is hitting the piston, the car won't turn by hand at all? I.e it will stick?? Or is it possible that it will hit and still turn over by hand?
thanks for any hel.
Old Sep 4, 2008 | 07:45 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Have you taken the spark plugs out?
Old Sep 4, 2008 | 07:46 PM
OldDan's Avatar
OldDan
Yes, just hear a slight sqeeking noise when turning it over but that could be rings or anything I guess as it's brand new engine...
Old Sep 4, 2008 | 07:48 PM
RWD_cossie_wil
Is it on verniers or anything like that?
Old Sep 4, 2008 | 07:49 PM
OldDan's Avatar
OldDan
No, they are keyless pulleys though.
Old Sep 4, 2008 | 07:51 PM
OldDan's Avatar
OldDan
Basically - the car is struggling to start, so I'm checking cam timing but don't have the tools. It was timed with bar and pin, but the inlet cam looks like it's slightly out, so I've moved it a little, to see if it helps...
Basically if the valves are hitting I'm wondering if I would still be able to turn the engine over by hand or would it stop dead when it hits the piston.
OldDan's Avatar
OldDan
And i've said Basically twice, but it's not really that basic. LOL
Old Sep 4, 2008 | 07:52 PM
RWD_cossie_wil
If it is only slight contact, the engine will still turn by hand, I take it the cams and pulleys are interferance fit and didn't come apart?
Old Sep 4, 2008 | 07:53 PM
OldDan's Avatar
OldDan
Yeah it's not come apart - undone cam pulley bolt and turned cam then tightened it back up..
Old Sep 4, 2008 | 07:55 PM
RWD_cossie_wil
How d you read off the timing marks then , is it a case of bolting a block onto the top on the cam to lock it?
Old Sep 4, 2008 | 07:59 PM
OldDan's Avatar
OldDan
No timing marks!
Bar across the slots in the cam, and pin to stop the crank when it's timed up.
I think the slots on the cams are out though and they've been ground from two exhaust cams.. Possibly!
Old Sep 4, 2008 | 08:02 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Wheres the car Dan? I might be able to get someone to come look at it if its slough?
Old Sep 4, 2008 | 08:04 PM
OldDan's Avatar
OldDan
Manchester mate.
Old Sep 4, 2008 | 08:05 PM
Charlie Chalk
Unknown.
Bugger
Is the Diva far from you?
Old Sep 4, 2008 | 08:06 PM
OldDan's Avatar
OldDan
Far enough! I might just turn the fucker over and see what happens.
Old Sep 4, 2008 | 08:37 PM
The Youth.'s Avatar
The Youth.
what engine?
redo the cam timing before starting it..
steve
Old Sep 4, 2008 | 08:54 PM
OldDan's Avatar
OldDan
Zetec-SE given up on the progress tonight getting the correct timing gear and will give it a go tomorrow.
Cheers for help everyone.
Old Sep 4, 2008 | 08:58 PM
volcomstone411's Avatar
volcomstone411
puma then?
did you lock it tdc on piston 1, then lock the cams into position on the bar it should be fine.
Old Sep 4, 2008 | 09:03 PM
Wells's Avatar
Wells
1600 Zetec not puma.
Old Sep 4, 2008 | 09:05 PM
OldDan's Avatar
OldDan
Originally Posted by volcomstone411
puma then?
Cams are that wild i don't think it can be timed on standard marks.
I'll have a play tomorrow, and don't have the timing gear until tomorrow.
Old Sep 4, 2008 | 09:08 PM
rst in breaking's Avatar
rst in breaking
double check piston 1 and 4 are at tdc by looking through the spark plug gaps once locked, if so and cams are locked i cant see a problem, did you oil the bores when engine was assembled?
Old Sep 4, 2008 | 09:12 PM
OldDan's Avatar
OldDan
Oh yes.
It's the cam timing Ill have a proper play tomorrow.
Old Sep 4, 2008 | 09:16 PM
rst in breaking
good luck then mate, have you had the head skimmed? maybe too much?
Old Sep 4, 2008 | 09:21 PM
Charlie Chalk
Unknown.
Hope you sort it mate
Old Sep 4, 2008 | 09:45 PM
OldDan's Avatar
OldDan
Heads not skimmed and pistons have huge cut outs.
Old Sep 4, 2008 | 10:04 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Dan, these are the lairy cams right? Did you not get proper peak lift timing figures? You'll dramatically affect the powerband "guessing" where they go mate. Ring me on my mobile now if you want pal
Old Sep 4, 2008 | 10:06 PM
TWoods's Avatar
TWoods
If ground from 2 exh cams the timing bar will be 100% wrong. Think about it the in cam slot facing left and exh facing right when timed to tdc left and right slot will be facing each other so the bar will fit, if both cams ground from exh cams then one will be 180 degrees out hence valve to piston contact.
Old Sep 5, 2008 | 07:22 AM
OldDan's Avatar
OldDan
There wasn't valve to piston contact originally - and it wasn;t starting or revving.
Now there is a slight tap and it starts and revs a little, so I'm glad it's confirmed it's the cam timing. Will time it up propper now - clock is counting down - gotta be in london by 6pm!
Nov 1, 2015 06:53 PM
Chas
Oct 5, 2015 07:13 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
