engine temps
hi guys,
just wondering if i need 2 worry,my car after the re-build seems 2 b running hotter than b4.I have a pace 500 inter-cooler and standard rad. The tempreture on a run is between 88 and 90 but when i stop it reaches 96 and the fans seem 2 have trouble bringing it down until im on the move again. Just wanted 2 know if this usual. Any opinions would b appreciated.
cheers matt
cheers matt
They do tend to run slightly hotter when new, but those temps are nothing to worry about, fans stay on a long time on cossie unless you have the more suitable rad fan switch from msd, which switches on at 92C and off at 88C, whereas the std ones spans a 10C drop, so consequently needs much longer to cool this much more.
Wilsfoci
15
Mar 30, 2016 10:26 PM
Harryh24
Aug 26, 2015 07:50 PM
