Trigger Wheel Help
Old Sep 4, 2008 | 03:06 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
Default Trigger Wheel Help
when fitting a 36-1 trigger wheel is the missing tooth a refrence point to TDC for the sensor
how would you go about fitting one?
any help would be good
Old Sep 4, 2008 | 03:12 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
if you look on Traders parts fro sale CDF are making very nice bottom pullys for cossies with 36-1 trigers on them.
Old Sep 4, 2008 | 03:59 PM
ian sibbert's Avatar
ian sibbert
You can on most aftermarket ECU's define the trigger wheel parameters, what ecu are you using pal?
Old Sep 4, 2008 | 04:12 PM
clarke5700's Avatar
clarke5700
megasquirt
Old Sep 4, 2008 | 04:28 PM
ian sibbert
This might help pal, ive done a couple on 60-2 wheels.....
http://www.extraefi.co.uk/wheel_fitting.htm
Old Sep 4, 2008 | 05:14 PM
Mark RS's Avatar
Mark RS
if you can get the escort cosworth small turbo has a 36 tooth triger wheel
Old Sep 4, 2008 | 06:18 PM
Most ecu's that use 36-1 are set with missing tooth at 90 degrees before tdc.
Old Sep 4, 2008 | 06:20 PM
AlexF's Avatar
AlexF
for EDIS you want the marker at TDC and the sensor mounted 90 degress BTDC
Old Sep 4, 2008 | 07:39 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
I can second that one.
This is what my haltech and omex has worked just fine with
Old Sep 4, 2008 | 07:52 PM
clarke5700's Avatar
clarke5700
its going on a starlet turbo?
Old Sep 4, 2008 | 09:18 PM
AlexF's Avatar
AlexF
Are you using EDIS with MS or coil drivers?
Old Sep 4, 2008 | 10:16 PM
clarke5700's Avatar
clarke5700
em ford zetec coil pack
DixieTheKid
11
Jun 6, 2020 11:20 AM
Fiddy
21
Sep 29, 2015 06:10 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
