Cosworth management question. I del control valve not plugged in?
Old Sep 3, 2008 | 08:44 PM
muz's Avatar
muz
Wye Valley Hardcore
Default Cosworth management question. I del control valve not plugged in?
I've just picked up a Fiesta running Cossie management, but I've noticed the Idle control isn't plugged in? All the conversions I've seen have them plugged in.
Old Sep 3, 2008 | 08:46 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
That'll be the idle speed control valve.
Old Sep 3, 2008 | 08:52 PM
Rick's Avatar
Rick
idle speed may not be active
Old Sep 3, 2008 | 08:53 PM
muz's Avatar
muz
Wye Valley Hardcore
Just worked that out lol. Seems to Idle fine with it unplugged. The standard ISCV isn't there though. Strange.
Old Sep 5, 2008 | 08:14 PM
Zetecfiesta's Avatar
Zetecfiesta
if your running cossie management the iscv is under the bracket that holds the throttle cable in position! cossie managment doesnt the standard efi iscv
Old Sep 5, 2008 | 08:42 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You don't need an ISCV for a car to idle properly! In most production cars its there for various things, like anti-stall and cold start, but rarely to control idle!
Old Sep 5, 2008 | 09:14 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
idle valve might be fucked, plug it in and see what happens....if it doesnt idle, the valve is fucked!
Old Sep 5, 2008 | 09:25 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
That'd be my guess....only times i've seen them unplugged is when theyre fucked solenoids so the owners/tuners unplug them.
It's mainly for cold start and things like aircon kicking in at idle etc... not really a problem I wouldnt have thought.....and the sensors arent cheap so tend to be left unplugged.
Dan
Old Sep 5, 2008 | 10:04 PM
muz's Avatar
muz
Wye Valley Hardcore
Yeah I plugged it in and it started to idle at 3K rpm. Starts ok from cold with a little throttle, and i mean little. I've driven it around town and its been fine. Driven it home 200 miles and it was fine, and that included starting it from hot at the services so i'm guessing its ok for now. I've turned the heater on full with wipers on and radio playing and it Idled fine so I'm guessing its fine. Just wanted peice of mind for why it was unplugged. Will be getting set up though to make sure. Cheers guys.
jay030787
Sep 18, 2015 07:34 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
jay030787
Aug 17, 2015 06:16 PM
Aug 14, 2015 07:29 AM
muffster
Aug 11, 2015 05:39 PM
