Fitting a 023 pump
Old Sep 3, 2008 | 07:59 PM
Lighty's Avatar
Lighty
Default Fitting a 023 pump
As the title really fitting a 023 pump. I have done a search and found a few of you have fitted them. But still not to sure.
Did you cut the outlet pipe down slighty.
What about the the return pipe i see that some people have cut the plastic holder off is that right
And what is this?
And finally how did you guys connect the pump. Did you use a rubber pipe. Any pics that you have that would help would be great. Thanks Steve...
Old Sep 3, 2008 | 08:21 PM
cossiedave's Avatar
cossiedave
sham to cut that one up it looks mint but yes you cut it and pull the pipe out then you may have to drill the hole out to take the new fitting hope this helps
Old Sep 4, 2008 | 06:45 PM
El Grand Tomismola's Avatar
El Grand Tomismola
My intank pump may be coming out tomorrow (due to a bad connection)
Its an 023, so i'll take some pics of what the layout looks like
SteveyDee
Aug 24, 2015 05:43 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Dubs44
Aug 21, 2015 02:42 PM
3doorcozmess
Aug 21, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
