Rs 2000 Mk6 with ABS Rear disc Conversion
Old Sep 3, 2008 | 05:33 PM
MasonRS's Avatar
MasonRS
Default Rs 2000 Mk6 with ABS Rear disc Conversion
Hi there ppl im wondering if any one can help me im stuck with this problem of converting my rs 2000 mk6 with abs to rear discs. Ive bought the rear discs off a mk5 rs 2000 but it has not got the abs what should i do? i know it can be done but how? Can anyone help?
Old Sep 3, 2008 | 05:49 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Have a look HERE for a bit of inspiration. The mk5 beam is of no use to you unfortunately.
Old Sep 3, 2008 | 07:29 PM
MasonRS's Avatar
MasonRS
I looked at that on the internet but my problem is i spent £100 on the bits for the conversion. So dont know what to do now, does anyone know if this will work, if i got the mk5 disc shield and bolted it on to my mk6 axle kept the axle stub with the abs on it, and took the hub off the mk5 to be machined with the abs ring on. Do you think taht might work, or is there another way??? thanks for the replies too
Old Sep 3, 2008 | 08:46 PM
Phil2002's Avatar
Phil2002
you can use focus st/tdi rear hubs with a little modifying of the abs sensor have a look on www.escortevolution.co.uk there is thread on there about it mate i think puma speed did the original focus conversion.
Or ditch the mk6 abs and get a mk5 abs unit and ecu and run a complete mk5 abs set up.
hope this helps,
Phil
rex647
Mar 6, 2022 06:20 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
turbowag
Sep 3, 2015 08:07 AM
